TwinTurbo.NET: Nissan 300ZX forum - It could be lots of things or a combination..
Subject It could be lots of things or a combination..
Posted by Medallion Man on May 24, 2013 at 3:08 AM
  This message has been viewed 151 times.
In Reply To Help! posted by GotTwins90 on May 23, 2013 at 07:38 PM
Message Preventative maintenance id key to keeping these old girls running right...
first off check every connection you can find for corrosion, good contact and clips (be careful not to break any).
check CAS, MAF, PTU, TPS, injectors & coil packs...
check and replace air & fuel filters & spark plugs.
and read this..
La-Z-Link
also run diagnostics on the ECU and if still no clue maybe get conzult, ecutalk or other software to investigate...
Or take it to a 300zx competent garage (few and far between)
